3m vhb 4910?
MrDesignGuy
I am installing 8 - 3' x 5' 3mm PVC signs to a semi-gloss latex based paint on the interior of a building. Will VHB 4910 (clear, not foam) hold these signs up? Maybe I need some silicone or Urethane caulk to go along with it? Thoughts?
Thanks!
petrosgraphics
a 3x5 sign is pretty good size, no way of knowing if the wall is nice and flat....
if it has a cup in it vhb tape will not hold...... i have always used PL400 along with vhb tape
hoping the wall is flat.......
skyhigh
eeeekkkk.... hope you don't ever have to remove these. The vhb and/or silicone will take the paint off. If that isn't a concern, then I would use both. I wouldn't trust this size to just vhb.
How bout some decorative standoffs?
I don't think 4910 or 4905 is the correct application for this tape in this situation.
Check with a 3M representive for the correct information.
MrDesignGuy
What do you guys think about a panel clip such as a Z-clip for this job? Never used them, but seems like the right hardware for a worry-free install.
