4 Pass mode issues (Onyx Production House 7)
Discussion in 'RIP Software & Color Management' started by njohnston, Mar 28, 2010.
  1. njohnston
    njohnston New Member
    12
    When I try to print in 4 Pass (fast) mode using Onyx Production House 7 my image explodes to 3 times the size. All media profiles do this. I'm printing to a Mutoh 1614. 8 Pass works great but I'd like to use that fast banner mode for things that don't require high quality.
    Anyone ever see this?
  2. njohnston
    12
    little more info on this one. Onyx 7.3 and it only has issues in 4 Pass Bi directional. Uni seems to work fine.
  3. mzoty
    mzoty New Member
    8
    Dec 2, 2008
    Budapest
    Hi,
    If you change an extant (factory) profile in the Onyx which has a set number of passes, this will the throughput.
    If you want to print in 4 pass mode you have to make a brand new color profile for that media.
    conclusion: in the profiles of the onyx, you can change the effect, heat settings, or you can determine the head speed (240cps/320cps).
    If you change any other settings (pass number, resolution, ink drop size) you will have problem with the throughput of the print.
