bnosanchuk
I'm hoping the community here can weigh in on this for me as I keep getting different answers from different places. Originally, we were using a 45 degree blade on our Roland Sp-540V. But as our small lettering kept tearing, someone recommended switching to a 60 degree blade for fine detail work. We switched, and everything was going great. But, we've also been cutting some very heavy 6mil vinyl (not lettering) and broke the 60 blade in about two months. Is this normal (seller told us it would last 8 months)? We are also going to start cutting some very thick laminate at 10mil and are wondering if we should go back to the 45 blade for that (thinking the angle will last longer against the heavier material). But another source said to use the 60 for thicker material, not delicate cuts. Wouldn't the tip break and wear much faster as the angle is increased? And then a third source said we should be using the 45 blade for all our vinyl and 60 only for masking.
When and what do you use your blades for and do you swap them depending on the job?
