45 or 60 degree?
ams
I can't remember if its better to use a 45 or a 60 for cutting Oracal reflective, I am pretty sure it's 60 degree at about 120 force, does that sound right?
VINYLIMAGEZ
60 degree blade and always run the test cut from the plotter, apply the pressure needed, then cut your sign.
Jim Doggett
45 for reflective should be fine; it's not that thick. More pressure should help since it's a more rigid material.
IMO, blade angle is for thinner vs thicker material.
ams
Yeah I think the 60 is designed for things such as Multi-Lens vinyl which is mega thick.
