5-6yr old vinyl removal
Discussion in 'General Signmaking Topics' started by WVB, Apr 20, 2010.
  1. WVB
    WVB Very Active Member
    2,749
    Curious if this CrystalTek's Vinyl-Off really works as easily as stated... I have to give a bid on a old isuzu bread truck. Vinyl looks to be on there for at least 4-5yrs perhaps longer. Stuff is 3M most likely 180c as it is leaving the dot pattern behind in areas.
    What are some of the things you guys do/use for such as this?
  2. Jillbeans
    Jillbeans Major Contributor
    14,457
    20
    38
    Dec 24, 2003
    Butler, PA
    Rapid Remover/L'il Chizler/hair dryer.
    Some use a wallpaper steamer.
    You can also shine those auto body lamps on the thing or park it in the sun.
    Be sure to charge accordingly.
    Love....Jill
  3. WhiskeyDreamer
    WhiskeyDreamer Professional Snow Ninja
    3,585
    89
    48
    Aug 6, 2007
    Riften
    vinyl off DOES NOT work as easily as indicated by their ads....
  4. firesignz
    firesignz Celebrating 10 Years in business
    58
    2
    6
    Apr 13, 2010
    Mt Sinai NY
    Heat gun, thin edged plastic squeegee and a lot of time. I have tried all sorts of "remover" chems with little success.
    Standard van lettering removal usually takes me about 2 hours (outdoors in the bright sun). Be sure to keep heating ahead of yourself as you pull (don't hit the removed area with the heat as it will make it rip).
    Oh and charge enough to make it worth while. It is a lot of work to do it clean
  5. cajun312
    cajun312 Active Member
    598
    3
    18
    Jun 26, 2005
    Louisiana
    I have tried the CrystalTek stuff and sometimes it works great, sometimes it makes little difference, I'm guessing it depends on the brand and type of vinyl, everything I've used it for has been jobs other shops have done so I never know what kind of vinyl I'm removing.
    Mark
  6. Gino
    Gino Premium Subscriber
    34,436
    2,626
    113
    Jun 7, 2006
    PA
    flame thrower.jpg and a lil' chizler.
  7. JR's
    JR's Very Active Member
    2,916
    110
    63
    Sep 6, 2007
    swansea Ma 02777
    Gino :thumb: :thumb:
    first wash with GAS.
    JR ;-}
