5x10' RTG MDO?
Discussion in 'Materials' started by john1, Jul 10, 2012.
  1. john1
    john1 Guest
    Hey guys, Have a customer who seen a 5x10' dibond sign i did last month and want the same size but something that will go between 2 posts for a double sided sign by the road.
    The sign will be advertising commercial space for lease and the biggest i can get RTG (Primed and painted) MDO is 4x8' at 1/2 or 3/4" thick.
    I will be providing the double sided sign face with a digital print only, They will frame/install.
    I am looking for something that i can buy, and directly place graphics onto. I do not paint nor have a place to paint at.
    Thanks!
  2. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    17
    2 s/s diebond attached to exterior plywood structure that he builds. Doubt you will find RTG mdo in that size, and it most likely will want interior structural support anyway.
  3. Circleville Signs
    Circleville Signs Very Active Member
    2,140
    11
    38
    Sep 30, 2009
    Circleville, OH
    10mm Alumacore.
    Simple.
  4. CanuckSigns
    CanuckSigns Very Active Member
    3,440
    400
    83
    Nov 11, 2008
    Ontario
    This
  5. john1
    john1 Guest
    Thanks guys, My supplier doesn't have alumacore in 10mm but i am thinking i can give the customer a option of 2 3mm dibond panels and 2 .063" aluminum panels for price comparison to be attached to plywood.
    That makes the pricing per panel about $123 different so hopefully one fits their budget.
    Sound good?
  6. ChicagoGraphics
    ChicagoGraphics Major Contributor
    4,847
    70
    48
    Feb 27, 2007
    World
    Check with your local lumber yard, around here they carry 1/2" MDO 6'x12'
  7. skyhigh
    skyhigh Major Contributor
    4,866
    10
    38
    Jun 16, 2005
    PA
    If you have a couple saw horses, a paint pan & roller......then move the car out of the driveway. Its time to learn how to paint.
  8. 2B
    2B Very Active Member
    3,043
    394
    83
    May 5, 2011
    TX
    2 sheets of 3mm ACP
    make a frame out of aluminum or metal square tubing, the signs mounted on each side
