60" dry erase laminate
BigfishDM
Unfortunatley its only available in 54" but like I said try some normal gloss laminate and see how it does for you.
Sign Eagle
Try Fellers', if you try std. laminate with a dri erase pen and and it works, you better supply the pen with your print. I supplied something once after trying a pen I had and it was no problem, after the customer used a different brand, I couldn't find anything that would get his marker off, had to replace the print.
