631 Wall vinyl check
J
john1
Guest
Hey guys, Just wanted to check to see where you all would be for this.
Using 30" oracal 631 wall vinyl (cut vinyl)
27x72" piece and 10x72" piece. File was previous designed for another job so it's ready to go, Just have to resize. Both are strictly lettering and customer is installing.
I have $100 for the large graphic and $45 for the smaller which is just shy of $8 PSF using graphixcalc
Thanks!
smdgrfx
Depends on your market. For this size, I usually start around $8 or $9 and then add more for difficulty if there is a lot to be weeded out. I also round up and add in any drop I may have. Also depends on the color. Is it something I have in stock or do I have to order in just for that one job...
J
john1
Guest
Yeah i had this color in stock, two small rolls actually.
