8600 cuts are off at back of cut
jmag215
So I mainly do snowmobile and dirt bike graphics. I use a 6 mil vinyl and a 10 mil lam. It doesn't matter if I use registration marks or not, my cuts will start out spot on and by the end of the cuts and be off by 3/4", it's like the heavy material doesn't feed at the correct speed or the excess hanging material holds it back. Any suggestions?
Decorworx
What is your acceleration set at and also the speed setting? When you use reg marks, do you use more than 4 marks for error correction?
jmag215
my acceleration is set to 4 and i have tried anywhere from 5 cm/sec to 50 cm/sec, no difference. when i use registration marks i set them at 18" apart. down the sides. so anywhere from 4-8 per side.
