Firstly I want to thank the team who started this forum. It is very useful.
I have a few printers that I have here that have different problems.
1. Mutoh PJ 3346NX - When i switch on the printer and it starts initialization it stops about 15cm and displays the following message SYSTEM ERROR E075 CR OVERCURRENT
2. Mutoh Valuejet 1304 - After changing the print head and running the nozzle check, it only displays CYAN & BLACK. YELLOW & MAGENTA are blank. I changed the head and tested it on another 1304 that we have and it worked fine. What could be the cause?
3. Mutoh Valuejet 1204 - When you switch on the printer it displays the error message E068 PF-ENCODER
I need help guys otherwise I might end up having a graveyard of printers by the end of the year.
