accuracy problem with D160R
bigben
When I use the print & cut feature, I don't have any problems. But If I cut a 48in X 120in rectangle of a 54in roll, I ended up with a 48in X around 119,5in. So I'm 1/2in short.
What is wrong and how do I fix this? Thanks.
PHILJOHNSON
Sales Manager
Hi BigBen,
What type of material is it you are using? Also, what software are you using for design and cutting?
Best regards,
Phil Johnson
Summa Inc.
FrankW
Try X-Calibration. You'll find it in the plotter menu. A line will be plotted, measure it and if neccessary correct the value shown on the plotters display. Be shure that autoload is activated. If using heavier rolls, use the media flanges too.
120in should be in the plotters range of repeatability, if everything is ok.
bigben
Hi BigBen,
Best regards,
Phil Johnson
Summa Inc.
Hi Phil,
My material is Mactac frosted vinyl. I'm using illustrator for my design and winplot (in the illustrator plugin) when I just do cut vinyl. If I do print & cut, I'm using Caldera.
