Acid wash for trailers?
ironchef
I heard people use some kind of acid to wash trailers to take off that white chalky stuff thats on there? Any tips, comments?
jfiscus
Rap Master
I have used Ghost Off (Fellers or Advantage sells it) with good success; put a bit more in the solution than recommended, scrub it well, then wash it off.
ggsigns
Aluminum trailers are sometime cleaned with hydrofluoric acid which is extremely dangerous if not handled properly. I would avoid using acid unless you know what you're doing. This from a former chemistry teacher.
Typestries
Another go to is LA's awesome. Wet surface, spray on, scrub, let sit for 30 seconds and rinse. Try an adhesion test before and after, you'll be shocked at the difference on older trailers.
insty
I just cleaned my car trailer last weekend. I use this. Piece of cake, just follow the directions. It's available at most parts stores. I use a pump sprayer to apply.
ironchef
Thanks guys, i used my carwash guy and he got up close and personal with it, turned out well
