I have a job coming up where this guy wants me to scan an old photo of his father into digital format and then print it wide format... this I am already setup however I had my vendor send me samples of Sihl 3699 Photoart and then GF Concept 106 optically clear mounting film. The issue I am experiencing was a little bit of silvering after mounting it with my laminator. After I took the sample piece I tried (have never done this before so I am working on figuring it out before I take the job) is it had a lot of silvering. I didn't try to use any heat assist on the laminator as I originally didn't think it would have been necessary. After I laminated it I hit it with a squeegee and a pretty good pressure and a lot of the silvering went away but there was still some and this really cant be part of a solid process. I did this on like an 8x10 sheet to start but my final product is going to be somewhere around the 3' x 6' mark. I also plan on using this for all of the way finding door signs inside as well and those will be smaller at 6" x 9".
My thoughts are that the gloss media isn't as smooth as it should be for this application and that a thinner and smoother high resolution type surface material would be better. Its not rough but if you look close you can see a slight texture that could be causing the gaps.
So I am looking for a suggestion on process, a recommendation on materials or if someone knows of a thread to review that would be a great start as well. I searched a few terms but after reading through the articles nothing came up to help.
I am using an HP Latex 360 to print.
Thanks!
-Charlie
Thanks!
-Charlie
