Acuity/Caldera - Glossier print setting or technique
WalkerP
Is there a way to make prints more glossy without using a varnish? Maybe lowering lamp power while printing and then post curing to finish? I've done that on smaller flatbeds, but not on the Acuity. Maybe a gloss print setting? Any techniques and/or tips?
AlsEU
Acuity doesn't have any mechanism for change of the finish except swap of inks (KO are more glossy than KI for example). Playing with UV lamps power won't make a big difference imho, it's not Onset, where you can change the finish.
GraphicsSource
Adjusting the UV lamps can make it a bit more glossy. From my experience basically the longer the ink sits on the substrate before the uv lamps hit it, the glossier it will be. Lowering the lamps helps sometimes too.
Maybe try turning off the trailing lamp and only use a leading lamp so the ink sets for a second before being cured.
DougWestwood
delay setting
You can also set the print module to wait a bit before doing another pass.
FUJI Acuity has a "pause" setting for the module to go back and forth.
I think it's in the same menu as the lamp settings.
Good Luck!
