adhesive for inside of window
james2
Hi,
I applied perf to the inside of a window using panostick adhesive sheets.
seemed to work well for about 2 months until the store owner mentioned that they are starting to fall off. Has anyone else had this problem? Do I just need to re-apply the adhesive every few months?? Is there a stronger clear adhesive I can use to re-apply them? frustrated.
BigfishDM
I sell an optically clear permanent/removable double sided face mounting adhesive that would eliminate that problem.
Slyboots
James, I have the exact same problem. I was wondering if you found any solution or if the manufacturer resolved the issue for you. I was told recently that the PanoFilm was discontinued and replaced by a product that works. I unfortunately have already done a huge job with it and it's slowly but surely coming off all the windows.
