adhesive removal
Discussion in 'Tips & Tricks' started by K2, Jun 7, 2010.
  1. K2
    K2 Member
    217
    3
    18
    Nov 3, 2009
    Arkansas
    I have an old cargo trailer that has refective vinyl on it that has to be removed. I can heat and pull off but its leaving alot of the adhesive behind, I tried using "Rapid Romover" but that softens the paint up so much i can rub it off with a paper towl. Works good on the adhesive removing though, haha. Any Ideas.
  2. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    17
    I have had success using ALOT of paint thinner to soften it up, then scrape off w/squeegee (create's a boogery mess, but works) - this was on aluminum painted with matthew's, so you might want to try an inconspicuous place on the trailer, since the paint softens w/only rapid remover...
  3. Pat Whatley
    Pat Whatley Major Contributor
    8,593
    86
    48
    Sep 29, 2003
    Wetumpka, AL
    Step 1: Make damn sure the customer understands the problem, and accepts the risk of a repaint before you go any further. They usually don't have a problem with it as long as you warn them up front.
    Your problem is you're trying to get the most aggressive adhesive off a substandard paint job. I'd try straight denatured alcohol. It's not as aggresive as a typical adhesive remover. If that doesn't work then give Goo Gone a shot. After that I'd try lacquer thinner but be prepared for that to kill the paint.
  4. dwt
    dwt Member
    298
    3M 08984 Wear some disposable gloves and use a chizler or two or three.
    Like jhill and pat said, be ready to take the finish off with it.
  5. Marlene
    Marlene Major Contributor
    10,970
    264
    83
    Jun 8, 2004
    Vermont
    boy, it shouldn't do that. you might try an orange based remover like you would get at a hardware store. they are les agressive so there's more work but because they are less aggessive, they might not remove the paint
  6. BobM
    BobM Very Active Member
    2,148
    45
    48
    May 31, 2008
    Cape Cod
    Almost any chemical you use will get to the paint. You might try using a wallpaper steamer ($50 Walmart) to soften up the adhesive and gently scrape it off will a lil chillizer or plastic razor blade and a "damp" cloth with Rapid Remover on it. Touch and go no matter what you do. Charge by the hour and let the customer know what you're up against.
  7. omgsideburns
    omgsideburns Very Active Member
    2,180
    Apr 15, 2008
    try glue off.
  8. Sign_Boy
    Sign_Boy Major Contributor
    6,429
    8
    38
    May 18, 2007
    USA
    That stuff is aggressive - I wouldn't use it.
    Do you have a cat? :ROFLMAO:
  9. Mosh
    Mosh Major Contributor
    5,809
    41
    48
    Oct 19, 2009
    Nerbaska
    3M remover.
  10. rwinninger
    rwinninger Member
    39
    I ran out of rapid tac the other day so I used the denatured alcohol, worked great no gummy balls to contend with.
  11. skyhigh
    skyhigh Major Contributor
    4,866
    10
    38
    Jun 16, 2005
    PA
    alcohol on a crappy paint job will only make matters worse. Try "goof-off" (purchased at your local hardware), its one of the best adhesive removers I've tried, yet easier on the paint.
  12. daveb
    daveb General Know-it-all
    249
    Feb 11, 2010
    Quincy, IL
    OK here goes, everytime I mention this everybody goes "Oh Know!". I'm the old "know it all" here at the shop everybody comes to and starts whining when they can't get something done. For adhesive I go out to the shop and grab the mineral spirits, I know, I know everybody whines "it'll ruin the paint" "it's too harsh", "you may get some on your hands and you'll die!" to which I say BS, man up woosies... I've been using it for this purpose for twenty plus years and have NEVER ruined paint, soak a rag real good, wipe it on, wait 15 sec. wipe over it again. Keep paper towels handy to clean the boogies off your chiseler. Haven't seen the adhesive yet that it wouldn't take off, even the old dried up stuff, just keep it soaked longer. Heck in the old days we also used leaded gasoline, maybe automotive paint has changed since then but I never ruined any paint with it either and it worked pretty darn good. I know, I know, if I breathe the fumes too long my wee wee will fall off, right. I was my father's grease monkey from about 5-17 years old and my wee wee's still fine, heck my grandfather was an auto mechanic since before there were autos and his was still good well into his 80's (I know cause grandma used to complain about it) and lived until a week before his 90th birthday, he'd probably have made it that extra week if he hadn't breathed in all those nasty fumes.
    I'm rambling, Nuff Said.:cool:
  13. Gordy Saunders
    Gordy Saunders Member
    423
    Gasoline.
  14. daveb
    249
    Feb 11, 2010
    Quincy, IL
    :supersmilie: Cool, another one comes out of the closet :iamwithstupid
  15. MikePro
    MikePro Major Contributor
    5,005
    246
    63
    Feb 3, 2010
    Racine, WI
    i've been able to pull reflective adhesive off, in warm weather, with duct tape and a light+rapid touch. Just keep dabbing at it.
    otherwise, rapid remover was always my go-to... only has made things worse for me on semi-trailers.
  16. K2
    K2 Member
    217
    3
    18
    Nov 3, 2009
    Arkansas
    Well I pretty much tried everything that was suggested from paint thinnner to gasoline and finally got the best and easiest results with "Adhesive Off" fom fellers and a pressure washer. Thanks for all the help and learned alot of tips and tricks.
  17. Jillbeans
    Jillbeans Major Contributor
    14,457
    19
    38
    Dec 24, 2003
    Butler, PA
    I'm glad it worked out OK.
    I was just going to add that I have had "Goof Off" remove automotive paint when removing old stickers.
    Love....Jill
  18. AUTO-FX
    AUTO-FX Very Active Member
    2,185
    Having previously been in the autobody business, i would like to share my experiences with Crest products. After using 3M general adhesive remover for years, I was introduced to Crest Hi-Solv by the local sales rep from Crest East Coast. You can view all of Crests products at cresteastcoast.com . Hi-solv is listed under "brake and solvent" . It is an excellant, excellant adhesive remover, and will not harm most automotive finishes (urethane). Any paint on a trailer or painted aluminum panel should be tested first as this is an enamel and not a urethane. Crest Acry-solv may be a better choice if you're worried because it is not as strong. To purchase Crest products, you'll need to set up an account, but it's worth the time.
    Back to the problem, the reflective film has a membrane between the adhesive and the reflective layer. Usually mechanical means are needed to break the membrane and get the solvent down the adhesive layer. Lil chizlers are a good tool in combo with the solvent.
    3m Woodgrain remover (comes in a spray can) is good on some things. It has strong enough solvents in it that it actually melts through vinyls to get to the adhesive. On some older reflective films it works nicely. Always test first.
    Years back, i had a company come to me with used trucks purchased from Keeblers. They had six foot keebler elves printed on 3M reflective vinyl. No way were we peeling 6 foot elves off the side of these stinkin box trucks. I told the customer the only thing to do was paint over the box sides and apply the vinyl lettering over top. That weekend we roller painted these trucks with MAB Minute Dry white semigloss. Customer was thrilled. We were thrilled. Great paint, BTW .
  19. elsignshop
    elsignshop Member
    228
    Jul 1, 2010
    Douglas, Ga
    i always have a bottle of " prep all", i paint cars alot, so i always have some laying around. prep all is just a adhesive and wax removal used before painting a car to get all the dust and wax off. but i did a old cargo trailer today and i heated the old adhesive, used a plasic scraper, little chizzle. and goo off. and nothing worked and my wife desided to get a little bit of prep all and it came off pretty quick and got if off. so try that. you can get it at autozone or advance auto parts, i thinks it like 8 or 10 bucks.
  20. GypsyGraphics
    GypsyGraphics Major Contributor
    4,276
    4
    36
    Mar 19, 2009
    I just started using Mr. Clean Magic Eraser (extra power). Had a tough vinyl remove that Rapid Remove didn't work on till i used the eraser. Worked fantastic and didn't leave any marks, even with a lot of pressure. can't figure out why it worksto look at it you wouldn't think it would work, it's very soft (not a scouring type). won't go out on a job without them now.
