Adobe AI - Embedded - Link
Discussion in 'Adobe' started by Tony Teveris, Aug 25, 2005.
  1. Tony Teveris
    Tony Teveris Active Member
    I see in Illustrator that I can either have embedded or linked artwork. I also see how I can change a linked object into embedded via the link palette menu but can I change an embedded object back to link ? or do I just delete and replace the original object ?
  2. Derf
    Derf Very Active Member
    Delete and replace the original
  3. vid
    vid Very Active Member
    1,442
    3
    38
    Jun 11, 2003
    California
    Vector images, no.
    Raster images, yes.
    Select the raster image ...Then, from the Links menu > Replace
    Select the raster image file from the pop-up menu
    "Check" LINK --- (REPLACE will be checked but grayed out)
    > OK
    You can also select the image ...Then, from the top MENU BAR > File > Place
    "Check" LINK --- "Check" REPLACE
    > OK
    Doing this preserves the placement and any transformations that you may have done to the original embedded file.
    Best,
    vid
