Johnny Best
Just read through this whole post. Interesting subjects on Open Source software, Macs, Windows and Adobe.
WildWestDesigns said:Legacy files are very easily able to be opened. I have yet to have a problem with legacy files, either with Ai or CDR. Now bare in mind, I'm saying opening. I don't not need beyond that that what I do when I receive outside files.
WildWestDesigns said:When I receive files, I don't need to go in and tweak the file directly. I don't need that ability. I just have to open it up and I'm good to go.
WildWestDesigns said:As far as SVG files, they are exceptionally big in the apparel world (which is where my creative field mainly is), if you don't deal much with that, I can see why you may never have that request.
If you're rarely ever having problems with client-provided artwork the stuff you're receiving must only be very basic in nature. What I mean by basic is artwork with flat object fills only, all fonts converted to outlines, no line strokes or effects/patterns applied to strokes, no transparency effects, etc.
It's a lot to ask of a client just to get them to provide artwork that fits those parameters; very often the person sending the art file is not the person who created it. It's an asset just being passed along. If it's an asset of a big company or recognizable brand you have to do what you can on your end to make the vector file work. Or you risk losing out on the project. If you don't have software that can natively open and edit that file it will create a bunch of problems. Adobe Illustrator is the industry standard for the mainstream advertising industry, particularly those fashion conscious Mac users.
I'm talking about just opening the art file properly and making sure it is production ready. I'm not talking at all about altering the appearance of the artwork.
I've seen plenty of PDFs that looked proper in Adobe Reader and then see all the fills get shifted into odd-ball soup when imported straight into CorelDRAW.
SVG files, just like PDFs, can be very very dodgy if whoever generated the files didn't do a little thinking first before hitting the "save" button.
WildWestDesigns said:Not at all the issue. I regularly deal with strokes/effects/transparencies.
I don't have to be able to edit the file in it's native form. I just have to be able to view it. That's it. I can even take a screenshot of that viewed vector file and do exactly what I need to do with no variation in workflow and still turn out a quality product.
If it opens up and views correctly, that's all that I need. I can take a screenshot of that and do my work if need be. My needs are probably not the same as your needs.
Taking a screen shot and working with what is really just a pixel-based image of the computer screen rather than the actual native artwork might be acceptable to you, but it is a total non-starter for me.
Now, how you would even be able get a screen shot of artwork saved in a recent-generation AI file is another conundrum. That's only going to be possible if the person who generated the AI file bothered to save it down to the version of Illustrator you're using. Otherwise you could try to drag it into Adobe Reader and hope the AI file was saved with PDF compatibility turned on.
But if we have to take screen shots from a client's vector-based PDF or AI file and re-create that, well, that's not the client's fault. And then the re-created artwork is only a copy of a copy and not the real thing.
When it comes to opening recent generation Illustrator and PDF files I haven't seen any non-Adobe drawing programs perform the task credibly.
And that gets back to why some of us have to use Adobe Creative Cloud. If you can live without it, that's cool. But don't expect me to follow your lead.
I use Adobe programs all day long and I pretty much agree with the exception of Affinity.When it comes to opening recent generation Illustrator and PDF files I haven't seen any non-Adobe drawing programs perform the task credibly.
It's all ones and zeros. It shouldn't be that hard to compile a program that can read .ai files and interpret attributes assigned by AI. Adobe CC is readily available as a checksum. The cost of an Adobe CC subscription should be a minor concern considering the thousands of hours you will spend writing the code.
Would it be difficult to port from one UNIX system on Intel to another Unix like system on Intel? No. In fact it's not that difficult at all.
One of my favorite apps on Linux was KMyMoney.
WildWestDesigns said:Yep, the only real advantage with keeping it as a true vector artwork is resolution independence. That's it. Everything else is the exact same process for me, regardless if it's a vector file or not.
WildWestDesigns said:It's amazing what tools are available out there.
WildWestDesigns said:One program that I use, actually rasterizes the PDF file, so that may contribute to that one particular program's rate of success. Again, my competence level does not diminish if I don't have a vector file at all. My process is exactly the same. Yours may not be, but mine is.
WildWestDesigns said:However, remember that this thread was actually talking more about having Adobe ported directly onto the Linux platform, so our little sidebar would actually be moot.
brycesteiner said:Affinity Designer has saved many files from Indesign PDF's for me. It opens PDF files better than AI (unless the PDF was created by AI). I'm sure that you are well aware of Indesign's issues of converting fonts to outlines -- especially script fonts. Affinity can merge those together in so there is no cuts going through things wrong in the vector programs.
The "warts" of re-created artwork might be able to hide in a stitching pattern. The same warts will show up far more easily in cut vinyl, routed lettering or large format printed graphics. You might have a good quick routine for creating stitching of every letter or object in a piece of artwork. But there's nothing quick or easy about having to vectorize a bunch of letters from scratch if the finished result is supposed to look good. It's a whole lot faster and easier to have the same typefaces the client used in the logo. The best thing is just being able to use a vector file of the client's logo and not have to waste any time re-creating any artwork at all.
Name a specific application that is a fully functional replacement for Adobe Illustrator, or even CorelDRAW for that matter.
People who are making signs, not embroidery stitching patterns, are stuck more along the lines of the process I have to follow. There's no point to us taking a screen shot of a PDF in Adobe Reader and working only from that. That doesn't make people like me incompetent either. The key thing is using the right tools for the job. If I can avoid wasting a bunch of time trying to fix a customer provided PDF or AI file simply by using the right software that actually makes me and my company more competent.
Like you I don't hold out much hope for Adobe to port CC to Linux. Part of the problem is the philosophy of some Linux users who think everything should be open source. Ultimately it's an issue of the sales potential and I think Adobe probably doesn't see much there regardless of how many up votes the idea gets.
When script fonts are converted to outlines parts of one character will overlap the next character. .....
