My experience with UV inks (Mutoh rigid and flexible) is that they are useful for many things but not suitable for outdoor stickers.
The inks seem to overcure in sunlight and the sticker may start to curl over time, and even fell off, if printed near the edges.
Cured rigid ink is like concrete and may break when folded, but has very good scratch and solvent resistance.
Flexible inks are softer and more flexible (of course) and I assume the roll printers (mine is a flatbed) normally use flexible or semi flexible inks.
In short, UV inks have some advantages, especially on hard materials, and the prints look very good with excellent sharpness and details.
Outdoor durability is good but soft materials may curl or break over time.
Color fading is acceptable, and maybe even slightly better than solvent inks due to the thicker ink layer.
UV inks works well on many materials and doesn't need heat to cure, so it is suitable for many things where other inks won't work.
The ink layer stays on top of the surface which makes the ink layer thicker and it doesn't adhere to all materials. Tests are always recommended.
Since there is no solvent vaporization, the odor is very low.
