Advice on cutter...
Discussion in 'Miscellaneous Plotters' started by geek_riot, Jun 13, 2005.
  1. geek_riot
    geek_riot Member
    41
    Well, there has been some sort of screwup with my Roland GX-24. It was delivered to the wrong address and rejected, so it is being sent back! I am quite frustrated at this point, as the company I purchased this from is at fault. So now the drawing board is wiped clean... I am open for any suggestions on a 24" cutter... SummaCut D60, or should I get the ROland GX-24, the Graphtec 24"...
    Thanks,
    you all rock!:U Rock:
    Kim
  2. Scott Reynolds
    Scott Reynolds Active Member
    828
    Summa, Graphtec, Roland. Thats the order I would buy today. Got the Graphtec, great cutter.
  3. jayhawksigns
    jayhawksigns Very Active Member
    1,209
    34
    48
    Jan 8, 2005
    Kansas
    I say Summa too, got ours ten years ago and wouldn't trade it for anything, except a new Summa.
  4. ChiknNutz
    ChiknNutz Major Contributor
    4,789
    2
    For me, I'd probably buy a Graphtec FC7000-series (the new 5100) due to the reg mark sensor. The Summas, although great machines, seem over-priced in comparison. I'd also get LARGER than 24" if possible. I have the D60 and it is great, I do wish it was larger and had OPOS.
  5. WVB
    WVB Very Active Member
    2,749
    I would like to add the Panther Pro series which now has OPOS. Plus you can get a lot of suppliers with the machine at no additional cost.
  6. seaviewsigns
    seaviewsigns Member
    343
    i have a Graphtec CE 3000-60.... would follow graphixtreme's advice if i were to buy one now. i'd like to have the registration feature now that i'm looking into printers, but i'm very happy with the Graphtec line.
  7. Decal_Designs
    Decal_Designs Member
    310
    May 10, 2003
    Fox Lake
    Bigger can be better, but not always necessary.
    If you're looking into a 24" cutter, I'd recommend the Summa D60. I did a lot of reading on most of the 24" cutter before I decided on the D60.
  8. Leondo
    Leondo Member
    347
    I have a Master 24".... *runs from the rioting crowd*
    [​IMG]
  9. geb
    geb Very Active Member
    1,847
    4
    38
    Apr 23, 2003
    Adirondacks
    My vote is Summa, Graphtec, Roland in that order.
    George
  10. Barry
    Barry Active Member
    659
    May 6, 2004
    I would put Summa and Graphtec about the same and then Roland at the end... I currently have a D60 for the smaller stuff and I can cut 30 inch material with my Versacamm.
  11. geek_riot
    geek_riot Member
    41
    Hello all, thanks for the advice. I went with the 24" Graphtec CE3000-60, and am planning on using it with Illustrator.
    Kim
