Advice on lettering a boat with vinyl needed
Dixonsignshop
Suggestions / Advice on lettering a boat with vinyl needed. I have been searching the forums with luck on the subject but want to put it out there. Oracal 751 ok for this? What is the best stripper to remove all wax and prep the surface properly?
:thankyou:
splizaat
I have used oracal 651 several times with absolutely no problems after several years...I am sure 651 or 751 will work.
Billct2
Don't know Oracal, use the best cast vinyl you can get.
We clean with a commerial auto body prep. But you can also use Rapid Remover.
