After trace,then sent to cut?!?!?!
Discussion in 'Flexi' started by SpazSigns, May 14, 2007.
  1. SpazSigns
    SpazSigns Member
    114
    I traced out a image my buddy was needing for his car, but once i sent it to the plotter it keep going over the same part until it cut thru the vinyl, i checked the settings it was set to only one pass. Any help appreciated. Thanks
  2. Shovelhead
    Shovelhead Major Contributor
    10,882
    16
    Objects on top of objects.........
    picture (3) circles on top of eachother....the plotter cuts all (3).
  3. Fred Weiss
    Fred Weiss Merchant Member
    20,534
    402
    83
    Sep 11, 2003
    Olympia, WA
    Sounds like you have some duplicate paths laying directly on top of others. Did you do any copying and pasting after you traced?
  4. SpazSigns
    SpazSigns Member
    114
    Did no copy and pasting, Will check the layers when i get home.
  5. Pala-gurl
    Pala-gurl New Member
    21
    also, i just had the same problem today!! my cutter kept going back and forth on the same line till it cut clear through the vinyll, if you have a tray that allows the vinyll to roll and its being cut make sure the vinyll roll, stays on the tray, if you dont have a tray make sure theres enough slack so it can continue to cut your design, i didnt have enough slack of vinyll for it to flow easily so because of the pressure of the roll, it didnt roll out, and my needle couldnt continue because the wheels werent feeding my material out....hope some of this made sense to you lol its kinda hard to explain, anyways good luck and hope your problem gets solved.
