Question Agfa Anapurna MW White Ink
Discussion in 'Digital Printing' started by Mike Pickett, Mar 27, 2020.
  1. Mike Pickett
    Mike Pickett New Member
    3
    May 28, 2018
    Lethbridge, Alberta
    Wondering if anyone can provide some insight on this issue. It seems that no matter what I do I have to spend 1/2 an hour to 45 minutes every morning getting the white ink heads flushed and cleaned before they'll print properly. I have to flush them with cleaning solution multiple times in order to get them to print... any advice on what I can do to prevent this or is it just time to replace the heads? I don't have the same issues with the colour heads.
    The machine is roughly 10 or 11 years old.
  2. Grizzly
    Grizzly Member
    180
    19
    18
    Sep 1, 2010
    Utah
    Do you have any kind of recirculation pumps between the reservoirs and printheads as well as from the reservoir to the tank? Have they stopped working? White ink is notorious for coagulating if not kept in motion.
    • Agree Agree x 1
  3. WYLDGFI
    WYLDGFI Merchant Member
    1,166
    87
    48
    Oct 27, 2006
    Linden, NJ
    Older units...Vutek...AGFA...etc. all had (and still have) recirculating pumps. Ours is air driven on our newest unit.
  4. Madams
    Madams New Member
    9
    May 9, 2017
    Wilson, NC
    White ink needs to be constantly moved around as it starts to clump up fast. Depending on how many fires are on your head probably needs to be replaced. I've gone replaced both of mine in 2 years. Now i print white everyday regardless if i have a job on not to kept the ink circulated
  5. signage
    signage Major Contributor
    9,512
    75
    48
    Oct 5, 2005
    Penn
    White ink need to be agitated to keep the titanium Oxide suspended and not settled (together/bunched and hard to reseparate)!
  6. Ben Bramwell
    Ben Bramwell New Member
    4
    Aug 6, 2020
    Australia
    We have an AGFA Anapurna Mw, as the guys say, good heads and keep the ink moving, we always run a test print in warming machine up, and we'll always run white or double white behind, just to keep stirring the pot so to speak.
    White ink is cheaper than heads is what I say...
    • Agree Agree x 1
  7. Andy D
    Andy D Very Active Member
    2,296
    426
    83
    Oct 20, 2014
    Hattiesburg, MS
    It's been awhile since I ran an Anapurna, seems like I would flush the white heads before I left at night...
  8. WYLDGFI
    1,166
    87
    48
    Oct 27, 2006
    Linden, NJ
    With the series 4 ink on our anapurna we don't have to. The ink is moved thru the system some and stirred in the main tank. We can come in, warmup the printer...give the heads a quick wipe and jet test.....off and running on that. Minolta 1024 heads are pretty damn reliable.
