Morning All,
I need to put some small graphics on a bunch of trash receptacles. I initially tried 3M IJ40 but it did not stick well. I then tried the 3M IJ380 That stuff does not stick well either. Plus its 3 times more expensive. I thought of trying some adhesive primer but that is another whole process (added labor). Plus if I have to wait for the primer to "tack up" that doubles my install time as there are over 100 of these cans on this property (x4, one on each side). So primer is out of the question.
The cans have texture to them. The only way I can describe is, its like the plastic parts on a Honda Element. I know. That is the part you are NOT supposed to wrap or put graphics on. But I removed graphics from the cans to begin with so I know something exists that WILL stick.
So I wondered if any one has a recommendation for a solvent printable adhesive back vinyl with with a really aggressive adhesive that will grab and stick really well to a textured plastic surface, outdoors, in the sun.
Thanks in advance!
Thanks in advance!
