.ai importing to flexi
Discussion in 'Flexi' started by ackerman139, Dec 3, 2007.
  1. ackerman139
    ackerman139 Member
    132
    hey guys, quick question...
    When importing fullsize .ai files into flexi, I always seem to loose some artwork. Ex: I import a full side panel for a rev xp snowmobile, and some design, shapes, and texts are lost and not imported (but they are there when i open it in illustrator).
    Has anyone had this happen, or know what i can do? Thank you!
  2. Sign_Boy
    Sign_Boy Major Contributor
    6,429
    8
    38
    May 18, 2007
    USA
    Export eps from illy then import it to flexi. eps will work out better.
  3. ackerman139
    ackerman139 Member
    132
    it still occurs with .eps as well! Thanks for the reply though! any other ideas? i am clueless
  4. Sign_Boy
    6,429
    8
    38
    May 18, 2007
    USA
    Save it down in version Like eps 8
  5. Marie
    Marie Member
    390
    12
    18
    Jan 31, 2005
    Hattiesburg, MS
    You may want to convert your fonts to outlines and outline all your strokes (object/path/outline strokes) and then save as eps. - Good Luck
  6. jenhuedepohl
    jenhuedepohl Member
    129
    Had this happen to me just this week. I quit Flexi & and all was fine when I started it back up. Maybe a Flexi memory glitch?
  7. pindesign
    pindesign Member
    62
    Just to be sure, are you certain that you are not using transparency effects on objects set to overprint in the .ai file?
    Becuase this will cause a faulty export from illy (art drops out)
    Gareth.
  8. jc1cell
    jc1cell Active Member
    596
    Jun 11, 2007
    76137
    I usually save all Illy cs2 or cs3 files as .eps version 10 when I want to take it to Flexi. Once in there I have to unmask it in order to access individual items of the design.
    Depending on your version of Flexi you may have to go to an even earlier version.
    jc
  9. Cy Fan
    Cy Fan Member
    181
    I have this problem when I have artwork outside the artboard in Illy. simple fix, either make the artbord bigger to include everything or once you open it in flexi it automatically creats a mask where the artboard was in Illy. just select all, ungroup, then arrange>mask>unmask and that should release the clipping mask and you artwork outside the artboard will be there. Also there will be a black box where the artboard was just de-select everything and click on the black box and delete.
  10. ackerman139
    ackerman139 Member
    132
    alright, awesome guys. The last post sounds like it may solve it. At first, i thought it was a computer issue, or flexi issue. But, i will try these when i get into the office today. Thanks again!!!
  11. ackerman139
    ackerman139 Member
    132
    Thanks for the help guys! CY Fan was right, it was my artboard. I am not used to that since i usually use photoshop about 100% of the time. But im lovin illustrator now that it works, really cuts down on rip time, and quality.
