air pockets in my lams....
Discussion in 'Laminators' started by depps74, Dec 12, 2019.
  1. depps74
    depps74 Member
    160
    7
    18
    Apr 28, 2016
    ct
    I am new to laminating. I have a Royal Sovereign 54". I have been getting pretty good results, but there is always some air or parts that don't get fully pressed down. I can get rid of these areas with a squeegee and the coverage of these is pretty erratic so I don't think its an uneven issue.
    Any thoughts???
  2. Modern Ink Signs
    Modern Ink Signs Premium Subscriber
    548
    136
    43
    Jun 27, 2008
    Waukesha, WI
    Sounds like you might need to relearn the laminating process or there is something not set right with your laminator or bad stock
    pics?
    if you are careful you can get bubbles out. You may see imperfections in the lamination when you do this. However over time these may wet out. Just depends on the severity of the issue
  3. JulieS
    JulieS Member
    91
    11
    8
    Jan 15, 2011
    Columbia, SC
    Not much help, but...you definitely shouldn't be having air pockets/bubbles-at least not a lot of them. Something must not be set right. If you could post some photos, it might be easier to tell what's going on.
  4. rjssigns
    rjssigns Major Contributor
    5,322
    591
    113
    Jun 4, 2007
    Home Office
    I have an RS and run it at the slowest speed possible. This allows the adhesive to "wet out" better. There are lots of other things to look out for also. I've posted some tips and tricks for laminating. I'll see if a quick search pops them up.
