Alarm Monitoring Signs - options?
Discussion in 'Materials' started by mnapuran, Jul 2, 2012.
  1. mnapuran
    mnapuran Active Member
    587
    11
    18
    Jun 22, 2008
    Plano (Dallas), TX
    I have a client looking for something in the 8x10 to 10x12 size for a yard alarm sign. Curious what the most cost effective substrate and stake options are in your opinion. He only wants roughly 25 or so this time around.
  2. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    16
    the one from our alarm company is .040 screwed to a 1/2"x1/2" 1/16"wall aluminum square tube
  3. mnapuran
    587
    11
    18
    Jun 22, 2008
    Plano (Dallas), TX
    He's open to PVC, etc as options as well if you guys think they will last and be cost effective
  4. 2B
    2B Very Active Member
    3,038
    393
    83
    May 5, 2011
    TX
    Check with your supplier,
    N glantz has a house brand ACP (be bond or be board something like that) that is less than 040 alum
    if they want durability that rules out Corplast or pvc
  5. cajun312
    cajun312 Active Member
    597
    3
    18
    Jun 26, 2005
    Louisiana
    Stouse makes them, and I think they also sell blanks in different shapes. A lot of the big screen print shops also sell blank shapes if your order isn't big enough to screen print.
  6. FireSprint.com
    FireSprint.com Trade Only Screen & Digital Sign Printing
    Do them in HDPE or Aluminum. Styrene or PVC will break down in the sun.
    When you need a larger qty (or if you want a bid for 25) let us know.
    -Gene
  7. Pat Whatley
    Pat Whatley Major Contributor
    8,592
    86
    48
    Sep 29, 2003
    Wetumpka, AL
    Polyethylene instead of PVC.
    For the stakes use 1/2" square aluminum tubing. If you want to really make them look professional then cut the tips to 45 degrees and order caps for the top of the tube from Outwater. Attach the signs to the stakes with VHB tape.
  8. royster13
    royster13 Very Active Member
    1,817
    2
    38
    Apr 3, 2009
    Montrose BC
    Stouse.....
