All gradients are pink
rjssigns
Working with a file that has a yellow to orange gradient. It's fine until I reopen the saved file. Orange/yellow gradient is replaced with pink to white gradient.
It won't let me change to another gradient or solid color.
Only thing different I did was Auto-serialize some fleet numbers.
Tested auto-serialize with some DOT #'s and that file is fine.
Other files with the same gradient seem to be fine after saving and reopening.
Frustrating.
bannertime
I really, really hope that F19 is way better at handling gradients. It's one of my only complaints with Flexi. Gradients such.
If you created the gradient inside Flexi, then I really have no idea, except maybe a rogue transparency filter?
If you created it in Adobe, you may need to do the bulk data in Adobe. Pretty robust, but not as simple.
rjssigns
Never thought about a transparency filter. Hmm.. In order to save time and a migraine I rebuilt the file. Only thing I can think of is there is something the new Flexi doesn't like about a Flexi file from 2015. Was running 7.6 Pro at the time and just got back into Flexi with my new printer.
fuzzy_cam
The Granbury Wrap & Sign Guy
I've had a similar issue. You can always make a new file and rasterize the gradient to basically make it a background for your cut file. Add your text/numbers on top of that with no fill and a contour cut effect at 0.00" that way it will still let you auto-serialize.
fuzzy_cam
AGREED. I've got an ongoing list of issues with Flexi but gradient support is the biggest. How come you can't create a gradient to transparency... drives me nuts! And if you create on illustrator and bring it into Flexi its a PITA to alter.
rjssigns
Thanks for the tip. I used the logo from the old file and generated two new files and they're fine. No clue what happened to the files from a day or two ago. Preview shows correct color, open them up and they're sickly pink.
