Alumacorr vs. Polymetal
rlmercer
Trying to decide which is more durable for a permanent 4' x 8' sign (mounted between posts): 10mm alumacorr or 1/4" polymetal. I generally lean towards polymetal for my signs, but was wondering the pros and cons of each.
Thanks!
My problem with fluted core is it dents easily. Might not be an issue in NC or CA, but around here signs near the road get dented from flying gravel and snow plows throwing crap at them in the Winter.
I lean toward ACM panel secured on at least 3 sides, no MDO backers. I slot the posts and bottom (and top if not shaped) cross member so a good 1" or more is secured inside the posts and framework.
ChicagoGraphics
Polymetal is the same as Maxmetal, I have a lot of 4'x8s on post without any plywood backing on them here in Chicago and I never had one come back as of yet.
