Aluminum Fabrication w/ baked Enamel
2B
looking for suggestions on who can do this this type of aluminum fabrication.
the acrylic and graphics are not a problem.
the specs:
.125 aluminum
Finish: Baked Enamel
Color: TBA
QTY: 55
Size: not sure about overall, the acrylic face is 3"h x 9"w for scale
Thanks for the assist
View attachment Desk Plaque.pdf
mpn
Fancy wording for powder coated.
Sorry I didn't read the part about needing them fabricated.
Desert_Signs
+1 on powder coat.
However, I'm trying to picture that thing standing up on it's own. I find it hard to believe it won't just fall over with a slight breeze.
Christian @ 2CT Media
Wouldn't the base need to be slightly longer if its free standing to prevent tipping?
There are a few shops here in AZ that can do that with CNC benders, try to find a precision machine shop that has a CNC plate bender or a Sheet Metal Fabricator with a heavy duty Metal Brake and a good operator.
2B
+1 on powder coat.
yes this point has already been brought up the architect, and was told its on the drawings so that is what it needs to be
Desert_Signs
Make a sample and test it. If it falls over easily, you need to cover yourself. In Writing. That you told them it wouldn't work and you recommend against it.
You can buy 2x5x.125 aluminum extrusion and cut it to the size. You need to buy two sticks and bend it on the brake. Than take it to local metal fabricator and they will powder coated for you.
