Am I saving the file incorrectly?
Discussion in 'Corel' started by Team Valhalla, Dec 17, 2009.
  1. Team Valhalla
    Team Valhalla Member
    201
    2
    18
    Sep 15, 2009
    U.S. of A.
    I'm having an issue opening up an EPS file after saving it.
    I'm using CorelDRAW X4. I'm doing a graphic for a yard sign. When finished it's 24" X 18". The file size is 28 MB.
    When saving the file, I'm exporting it as an EPS file. When I try and reopen it with Corel, it says there was an error while processing, file can't be opened.
    While it won't open with Corel, I can open it with Versaworks and send it to the printer.
    I'm lost!
    Sp
  2. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    16
    you should always save a .cdr for reworking, and export to eps as needed for output...btw you can turn off tiff preview in the eps export dialogue box, and get that filesize down from 28mb to like 300kb if it's all vector...
  3. d fleming
    d fleming Very Active Member
    2,778
    230
    63
    Nov 28, 2007
    Middleburg, Florida
    Are you using the open command or the import?
  4. Team Valhalla
    201
    2
    18
    Sep 15, 2009
    U.S. of A.
    Import....
    Wrong?
    Sp
  5. Team Valhalla
    201
    2
    18
    Sep 15, 2009
    U.S. of A.
    d fleming,
    I've tried it both ways now. When using the Open command, a text box pops up "Import PS/PRN". Click Ok and still get the Can't Open File statement.
    Sp
  6. J Hill Designs
    15,549
    16
    so you don't have it saved as a cdr for editing/reoutput?
  7. d fleming
    2,778
    230
    63
    Nov 28, 2007
    Middleburg, Florida
    Sounds like the right filter, ps interpreted usually does the trick.
  8. Team Valhalla
    201
    2
    18
    Sep 15, 2009
    U.S. of A.
    jhilldesigns,
    I saved the file the way you suggested.... bingo! So if I have a file that I want to print over and over, but let's say change a name on the board, I should save the original as a .cdr, then save the file with the desired name change as the EPS file so it will pull into Versaworks. Correct?
    Thanks for the help! My head often hurts trying to remember all the different features and things that need to happen in this software!
    Sp
  9. J Hill Designs
    15,549
    16
    :thumb:
