Another Backlit Question
Discussion in 'General Signmaking Topics' started by MI Bearcat, Sep 8, 2020.
  1. MI Bearcat
    MI Bearcat Member
    74
    10
    8
    Apr 1, 2015
    Canton, Michigan
    I have to replace a backlit panel with an new design. The previous panel just had translucent cut vinyl applied but the new graphic has two PMS colors (darker grey and a green) they want to match so I can't use cut vinyl and they are solid back ground colors with white lettering. Plan on doing two pieces of vinyl, one on clear and one on translucent white after reading many threads about this. What's the best substrate to use in this case, clear or the translucent acrylic/polycarbonate?
  2. unclebun
    unclebun Very Active Member
    If you're doing a digital print with the double layer method, put it on white translucent plastic. The choice of acrylic or polycarbonate depends on the size and your preference.
    • Agree Agree x 2
  3. MI Bearcat
    MI Bearcat Member
    74
    10
    8
    Apr 1, 2015
    Canton, Michigan
    Thanks for the info. It's small enough that I was going to go with acrylic as their current sign has yellowed quite a bit. Should we go with clear vinyl then on front and back with the white translucent?
  4. unclebun
    We put both layers of vinyl on the front. Clear first (unlaminated) applied. Then translucent white, with UV laminate registered on top.
  5. WYLDGFI
    WYLDGFI Merchant Member
    1,195
    108
    63
    Oct 27, 2006
    Linden, NJ
    We would do this as a Day Night Backlit for our clients. Print inline with CMYK and White ink....3 layers total and then laminate. Boom...all done and ready to apply.
    • Like Like x 1
    • Agree Agree x 1
  6. Billct2
    Billct2 Major Contributor
    7,462
    642
    113
    Mar 12, 2005
    New England
    Yep, the day/night prints from Wyld are great
    • Like Like x 1
