Any difference between clear and gray VHB tapes?
Signsforwhile
We have a ton of the clear stuff here we used on an interior job, just curious if it bonds metal as well as the gray VHB....
Moze
The clear is great at bonding metal. The only caveat is the surfaces should both be relatively flat/smooth due to how thin the tape is. It's not as forgiving as the thicker foam tape.
Moze
It's a pretty big chore to separate two flat pieces that are adhered with the clear VHB tape. The stuff is extremely strong. So if the pieces you're attaching are flat, and you have a ton of the clear like you said, I would use it.
4941 works on a variety of materials and is also extremely strong.
