Any Help Appreciated - Mutoh 1204
Hot Vinyl
Hot Vinyl
I am having issues with my Mutoh 1204. I just replaced the head about 3 weeks ago and it was working great again. Then on Thursday I noticed that my black had very minimal spots missing but figured I would do a cleaning the next day. I did several cleanings and my black got worse then I lost my magenta. As I was changing my cartridge out the whole printer went dead. It would not come back on. Then I took the power up panel off and tried it and it had power. Then the problem was it said magenta was out. I tried changing it and then got an kcmy s/c read error. I noticed that the id panel inside for the magenta was broken so I changed that out. I only changed out the magenta one though. I still am getting the kcmy s/c read error. I did change out the panel for the colors behind that sites right above the cartridges. I am wondering if there is any fix to this.
I also checked all cables and then are secure and pushed in. Is there something else I can check?
I was using bulk inks should I get original OEM inks and try to reset?
Does anyone have any suggestions?
Please help a lady out.
Thank you guys.
heyskull
Capping station problem.
Easiest thing to do is replace the complete maintenance station especially if the head is new.
SC
heyskull
Also the read error could be a problem with the chip readers. These are a common failure and I have replaced loads on mine.
SC
Hot Vinyl
Hot Vinyl
Thanks for your response. With the readers so you have to replace all 4 at the same time? I only replaced the magenta. Didn't see anything wrong with the others.
