Any MM print reverse clings
tsgstl
I have a customer that needs 2 images on static cling and then contoured. He would prefer them to be applied on the inside. I cannot print white so I was hoping someone in here had a company or preferably a merchant member?
x1 35’’ x 17’’
x1 15’’ x 28’’
As always thank you in advance
tsgstl
I have white cling material. I have never had luck with it sticking on the front printed side. Is there a material that works well like that?
SIGNTIME
reverse print on clear cling and laminate with white clear adhesive vinyl put a piece of tape over each crop mark before laming then cut out before plotting
