Any tips on printing to the take up reel for print and cut?
Discussion in 'Tips & Tricks' started by StickerGuy83, Sep 15, 2020 at 7:58 PM.
  1. StickerGuy83
    StickerGuy83 Member
    48
    2
    8
    Sep 25, 2019
    new jersey
    So I'm kinda stuck on this whole take-up reel. I'm using it to print multiple jobs at once (print and cut jobs) but no matter the winding direction, it seems that I have to un-roll it off the core and manually roll it onto another core for it to go through the graphtec correctly for print and cut.
    Anyone have any tips or tricks? I'm using HP Latex, Graphtec Cutter & Flexi.
  2. SignMeUpGraphics
    SignMeUpGraphics Moderator
    1,288
    266
    83
    Apr 11, 2012
    Australia
    Not sure how Flexi works, but we print multiple jobs down the roll with Onyx and once it gets to cutting, we select 180 degree rotation and then cut each job.
    If we laminate, no need to do anything, default settings are fine as the roll is forward wound once again.
    • Like Like x 1
    • Agree Agree x 1
  3. Snydo
    Snydo Active Member
    538
    28
    28
    May 1, 2008
    Mid Michigan
    In Production Manager look for a tick box that says "flip cut file" or some such thing and that should do the trick.
    You can also just take an empty core and stand it on edge next to your printed roll, tape the tail of your print to the empty tube and then place a thumb in each tube and spin with your thumb and forefingers in the same direction. Anything over half a roll is a real good workout.
    You can also just flip your print file 180 degrees and resend on HOLD.
  4. Notarealsignguy
    Notarealsignguy Active Member
    794
    199
    43
    Feb 20, 2020
    Florida
    Why aren't you laminating?
  5. balstestrat
    balstestrat Member
    85
    5
    8
    Aug 25, 2020
    Europe
    Graphtec doesn't have automatic barcode and automatic job direction?
  6. SignMeUpGraphics
    1,288
    266
    83
    Apr 11, 2012
    Australia
    Only on the FC9000.
  7. WYLDGFI
    WYLDGFI Merchant Member
    1,138
    67
    48
    Oct 27, 2006
    Linden, NJ
    Cant you flip your cut 180 degrees ?? That would solve your problem as well. In Caldera we have the option of 0 degree or 180 degree flip for cutting on our graphtec. Otherwise, what they are mentioning above is to automatically flip your graphic 180 degrees so when you get it on the roll to the cutter, it comes out correct for your workflow.
  8. StickerGuy83
    StickerGuy83 Member
    48
    2
    8
    Sep 25, 2019
    new jersey
    I don't see anything in the job properties for the cut where I can flip the cut job 180. I can flip the print job 180 in the RIP, but I will go ahead and assume that its going to flip the cut job 180 with it.
  9. StickerGuy83
    StickerGuy83 Member
    48
    2
    8
    Sep 25, 2019
    new jersey
    Screenshot me that "flip cut file" option lol
  10. StickerGuy83
    StickerGuy83 Member
    48
    2
    8
    Sep 25, 2019
    new jersey
    The fc9000 has barcode support, but its not an option in Flexi quite yet. I spoke to SAI and they said its in "beta". That option would be awesome if it was in there.
  11. StickerGuy83
    StickerGuy83 Member
    48
    2
    8
    Sep 25, 2019
    new jersey
    If my understanding is correct, if I do that, it will flip the cut properties with it.
  12. WYLDGFI
    1,138
    67
    48
    Oct 27, 2006
    Linden, NJ
    I dont know how Flexi works. With Caldera for us, it doesn't matter...we can flip the cut to suit how its on the roll. Im honestly surprised that flexi or whatever doesnt allow you to flip the cut or search for the cut at a 180 degree alternative.
