Any Wordpress Nextgen guru's...?
Moze
Precision Sign Services
On this page and this page, the thumbnails each have a black border and then a 'stacked' effect.
Does anyone know how to eliminate those items?
I would also like the thumbnails on those pages to be a bit larger.
I'm going to post on the support forum, but thought I'd try here as well.
Photos also attached...
LarryB
In your wordpress admin go to settings - media and you can change your thumbnail size. You will have to regenerate thumbnails afterwards. Easy way to regenerate them is with a plug in called - regenerate thumbnails.
I'm not sure about the black border issue as it could be a simple setting with your theme or it may involve css coding.
Moze
Thank you - I'll try the thumbnail resize plugin.
In the event anyone else runs into this, this is what was posted on the support forum...it eliminated the black border and stacked effect:
Goto Gallery->Style, do a find for :
background:transparent url(albumset.gif) no-repeat scroll 0%;
And putt // in front of the line to comment out.
//background:transparent url(albumset.gif) no-repeat scroll 0%;
If you have the nggallery.css in your theme you'll need to comment it out there too. Well the one in the theme overrides the the one in the css directory.
