Anyone have an idea what causes this?
D_P
It looks like a banding, but it's only doing it on one side of the print. printer is Mutoh XJ 1682SR. media is IJ180MC-10. Humidity is at 40%. I have tried different weave patterns setting too. Thanks for looking.
you mean data transfer or ink starvation?
Usually, if the signals going to the printer at some point get slowed down for whatever reason, it won't send a great deal of things being printed.
that's what I did and it seems like it is a damaged roll. thanks!
This is gonna happen, if your rolls are not stored properly. Usually it goes the opposite way under those conditions.
D_P
thanks for all the info.
ill look into that too because my data goes thru the network before it gets to the printer.
we have our rolls sitting on a pallet. it could've been damage in transport.
Modern Ink Signs
Is it happening in a consistent pattern? If it is it may be the material but is put money on ink starvation.
That is a large field of a solid color and can happen at your faster print speeds.
Out of the box profile(s) or have you built your own? Linearized your profiles?
D_P
printer is running at slow head speed. it is on consistent pattern about 10" apart. profile is built in house G7 certified.
Rohit Prasad
WWW.COMPASSCOLOR.COM
Looks like the media isn't all the way flat on the left edge. Does it do it consistently through out the roll or randomly?
Check and make sure the vaccum is working when the machine is printing.
If it's the media then raise the print heads and see what that does.
Reactions: D_P
Ogre
Similar thing happens to me when the media does not stay flat. Usually with the monomeric vinyl, wrong temperature, high humidity or just the vacuum lost its suction.
My printer is a Mimaki.
Reactions: D_P
I've seen this on my Roland's before. Seems to happen more on the side of the printer furthest from the capping station. That's all I got
Reactions: D_P
ToneCustomSigns
I have that same thing happen on Arlon SLX on my Mutoh 1624. Only on that material though. I haven't been able to figure out why.
Reactions: D_P
My guess would be roll problem or tension issue, or maybe encoder issue. I've never ran a 1682 but if they're like other mutohs I assume there are encoder strips for the carriage and advance. I don't think think that is the problem but cleaning those encoders is an easy rule out.
Reactions: D_P
D_P
Thank you for all the response peeps. it actually is a defective media. I changed roll and its gone.. :)
