Anyone have an old Ledco 30" Econocraft laminator?
eahicks
Need to know the amp size of the fuse in the back. Ours broke somehow and threw it away before checking the amp size. It's on the back, right side if you need to know...unscrew the black cap in pull it out.
And yes, I've tried to find out online.
Thanks in advance!
ProPDF
Thanks in advance!
need more spec info but here:
google: ledco laminator fuse
https://www.ledcolaminator.com/index.php?main_page=product_info&cPath=2&products_id=8
https://www.ledcolaminator.com/images/pdf/EP60V2110VACWIRINGDIAGRAMPRM218D.pdf
appears to be 3amp
Malkin
I have an old 60" Ledco Econocraft
Stamped on the fuse is: 3A 250V 312
It's nearly 20 years old and never blown, so thanks for letting me know where the fuse was in case it does....
ProPDF
I found the same thing....I assume that's the fuse they spec here. Only one it really could be.
We use to run them so I know what fuse you are talking about. I would call Ledco just to double check everything and make sure there were never any retrofits or service changes that could require different fuse size then the links provided.
RG
I have that laminator. 311 3AG is stamped on one end of the fuse. 5A32V is on the other end. Don't know if this is the original fuse or not. It probably is.
