Anyone have optimum settings for cutting small detailed type
Slow the speed down, use a 60 degree blade, and use an easy to cut font like san-serif fonts. Usually the rule is, if the text is shorter than half an inch tall, you will get unreliable results not matter the settings.
eahicks
I can get 1/8" tall with a fresh 45 blade, if cutting something like Helvetica. Have even gotten smaller than that. Don't recommend for a ton of text, but small stuff is possible.
shoresigns
Would love to know how you do that. Our machine just starts lifting up any sliver of vinyl it can and makes a mess of anything that small.
eahicks
For HP vinyl (like 751) my plotter Force setting as 14. Blade just barely sticks out of the holder. Like I said, when it's a fresh blade ( I have been buying Clean Cut blades), it works the best. I am sure if I tried any 1/8" text right now (blade is probably 3 months old) I would have some difficulty, but should be able to manage it.
MikePro
for small type, I cut & weed-out centers, apply graphic with a negative field still around the lettering & remove after the small lettering has adhered to the substrate.
