Hi All,
It's occurred to me that the way I've been removing vinyl from glass could be problematic. Since day 1 I've used a heat gun to warm up the vinyl and make it easier to remove. I'm quoting vinyl removal from 4 glass panels, each about 1/4 thick, tempered, exterior, approximately 6ft x 7ft for each panel. This is not the type of thing I'd like to see crack or turn into little tempered glass pieces.
Is heat the way to go to soften the adhesive under the vinyl, use brute force to remove the vinyl, or is there another way? Thanks all.
- denis
- denis
