FrankieTeardrop
Hello, I never had issues with this before but I'm applying large laminated print decals of 3m controltac vinyl to the sides of vans & I'm having issues with the deep body lines of the van. The decals are roughly 3'x5' & the problem is that the air is not escaping from under the vinyl. Before I had a printer I used to order the decals from a wholesale place & I remember the vinyl having a noticeable grid pattern & seemed a little thicker & the bubbles would just push right out. Am I using the wrong vinyl or should I wet apply? I had done a couple of these vans already & the vinyl is bubbling back up from that body line. I heated up the vinyl a lot with the heat gun but I can't tell if I hit the 200 degree mark to relax it.
