Applying to Coroplast
Discussion in 'Installation Equipment & Techniques' started by ScottyAdams, Jul 3, 2012.
  1. ScottyAdams
    ScottyAdams Member
    186
    Hey guys,
    Printing to vinyl and applying to 36" x 24" coroplast with a cold laminator. Any suggestions or techniques you guys might know or fill me in on before applying? Roller height? anything?
    fyi printed on Aspire calendered yellow vinyl. Thanks!
  2. Terremoto
    Terremoto Member
    207
    2
    I would just pre-mask it to give it a bit of stiffness and then apply it just like you would with cut vinyl. Probably quicker than monkeying around to get the roller height just right on the laminator.
    Dan
  3. mopar691
    mopar691 Member
    390
    Sep 15, 2010
    Big Squeegee would make fast work of this. I do not know a easier way.
  4. Gino
    Gino Premium Subscriber
    33,365
    2,344
    113
    Jun 7, 2006
    PA
    +1
  5. Wild Hare
    Wild Hare Member
    73
    Feb 2, 2007
    Quincy, Ca
    Big Squeegee Easy Peasy
  6. Pat Whatley
    Pat Whatley Major Contributor
    8,592
    86
    48
    Sep 29, 2003
    Wetumpka, AL
    Big Squegee and less than a minute of time.
  7. gabagoo
    gabagoo Major Contributor
    5,732
    106
    63
    Oct 10, 2006
    Vaughan, Ontario
    I would run it through the laminator.... Can do stuff like that in a minute...very easy
  8. Charlie J
    Charlie J Very Active Member
    1,876
    7
    38
    Oct 1, 2006
    Midwest
    Cut about 2-3 off of the backing and hinge the vinyl on the substrate. Make sure you get it absolutely straight. Put this edge in your laminator, peel the backing and run it thru.
    Piece of cake.
  9. Tim Aucoin
    Tim Aucoin Very Active Member
    Get a Big Squeegee... you won't regret it! Those who know me, know that I love making my little videos... so...
    Here's my latest video made today mounting 48" x 48" posters onto coroplast. Took me all of 5 minutes to mount 4 of them! For small runs, nothing beats it! :thumb::popcorn:
    http://www.youtube.com/watch?v=QbM86fwy1Uc&feature=plcp
    :ROFLMAO: I cut my head off in this video! I really need to start using a better camera! :rolleyes:
  10. john1
    john1 Guest
    If you don't have a BS you can wet lay it. I know when i first started laying vinyl on substrates i did this before getting the BS and it takes a bit longer cause it has to dry but it does get the job done in a pinch.
  11. d fleming
    d fleming Very Active Member
    2,778
    230
    63
    Nov 28, 2007
    Middleburg, Florida
    Print and mount in 4x8 layout, trim and done.
  12. jkdbjj
    jkdbjj Active Member
    906
    7
    18
    Jan 24, 2012
    Virginia
    The height on your roller should be at about 3mm or maybe 4mm, that will give it enough pressure. If you don't have mm, than use 1/8 to 3/16th of an inch setting. Just don't smoosh the poor thing.
    If you have a lot to do, the laminator is the way to go. If you have one or two, big squeegie can't be beat.
