Applying Window Cling To 18oz Banner
Vinyl slayer
They are signs for college campus restaurants. It is "Gudi" AKA "Briteline mounting film". It is a double sided removable adhesive. Typically we will use it on posters that are adhered to the inside of a glass door or window. The adhesive has pretty good tack but comes off with little force and usually completely clean. For some reason they want it on 18 oz banner instead of 24 pt ancora cardstock. No matter what I say they(and the owner of the company I am employed at) insist it must be on banner.
Sounds classy, professional and without a doubt the best option.
And what's a "douche-canal"? Did you call Gino a vagina? I thought you were creative.
Texas_Signmaker
Very Active Signmaker
Then do it and let them deal with the repercussion. Seems like a no brainer.
Vinyl slayer
So something removable, but can hold the weight of 18oz banner to a Window, with full surface coverage... But clear enough to see the graphic, "laminated" to scrim banner through the 2 sides of adhesive from the outside of the window. Is that what you're asking?
No, I am asking the best way to laminate 18 oz scrim banner.
hybriddesign
owner Hybrid Design
It should just laminate like any old vinyl. We lay it flat on a table and feed it in but there isn’t really anything special about laminating adhesive to banner
i have to admit that when I initially read window cling I thought you meant static cling too and thought you were crazy…
GAC05
Quit buggin' me
Wait... You said no, so you want to laminate a banner... But not with 2-sided adhesive... So why? You make no Sense at all. Is this thread some kind of joke?
Could be a glitch with Google Translate - he is from the country of Nor Cal.
Humble PM
Mostly tolerates architects
Apply the facemount adhesive to the banners, like any other lamination. Then take out the windows, run them through the laminator while applying the banner, just like to any other substrate. To help the adhesive cure, microwave for 30 seconds (remember, don't have any metal eyelets in the banner, they'll hurt the microwave).
Thank You. I hinge laminated them and it worked fine.
We have some weird internal terminology where I work.
