Aqueous print head to eco solvent print head
Discussion in 'Roland' started by Ultraman, Jul 9, 2020.
  1. Ultraman
    Ultraman Ultraman
    48
    Jun 7, 2018
    Xanada
    Hi! guys,
    I took an old dx4 print head from an Aqueous Roland FJ540 printer and installed into my VP540 and keyed in the new rank# and clear the old rank# but it says wrong head installed so I put in new flex cables but still said wrong head install but it will work in service mode and not user mode, how can I get by this issue?
    The magic question, can a Aqueous print head be use on a Eco-Solvent printer? Thanks
  2. Solventinkjet
    Solventinkjet DIY Printer Fixing Guide
    4,228
    796
    113
    Aug 2, 2011
    Denver, CO
    The manifold is going to melt when ink gets into it. You should put a solvent manifold on it before installing it. Also, the machine simply won't accept an aqueous head rank.Just use the old one. That should allow it to work.
  3. Ultraman
    Ultraman Ultraman
    48
    Jun 7, 2018
    Xanada
    Thanks first time speaking to you master. Interesting the manifold will melt but make sense bcos its partly solvent. The reason I inter-change the print head bcos my VP540 black head its done. So the final verdict is that my VP540 print head will not except Aqueous print head...at least I have a firm reply on this instead of kept trying. Im going to dismantle the FJ540 Aqueous printer for parts then....Thanks you my best friend now. why you put your phone# 303-733-6671 free troubleshooting? can I actual phone you if I need some tips?
  4. Solventinkjet
    4,228
    796
    113
    Aug 2, 2011
    Denver, CO
    That's what we do! We are fairly limited on Roland machines however. Myself and the other techs are all trained and certified on Mimaki and Mutoh printers but we also work on Rolands in the field but usually only the older ones.
  5. Ultraman
    Ultraman Ultraman
    48
    Jun 7, 2018
    Xanada
    Good to know. I know abit of Mimaki but more on Roland printers. I buy back and re-furbish Roland printers and sell but sometimes need a second opinion or stuck so its good that I know skilled friend like you. Thanks Soljet (short name to type..haha)
    • I Appreciate You I Appreciate You x 1
  6. Ultraman
    Ultraman Ultraman
    48
    Jun 7, 2018
    Xanada
    Master, is there a way to by pass the peak2 into service mode on VG and SG?
