Are there any small solvent machines?
Discussion in 'Miscellaneous Printers' started by Bogie, Jan 4, 2008.
  1. Bogie
    Bogie Very Active Member
    1,972
    Have an idea around something I'd like to do, but I'd basically just be running 15" material at the most. Any smaller systems?
  2. iSign
    iSign Major Contributor
    13,027
    31
    48
    Nov 29, 2003
    Kahului, Maui
    just get a 30"...
    just a guess here, but a 15" couldn't possibly save more then a few hundred bucks in materials, and with the limitation it presents almost nobody would buy it, making it far more expensive to produce.
  3. Gino
    Gino Premium Subscriber
    33,315
    2,327
    113
    Jun 7, 2006
    PA
    Badger, Binks and Paasche to name a few.
  4. Jackpine
    Jackpine Major Contributor
    There are many suppliers that will slit material to the size you need or are you wanting a 15" printer?
  5. Charlie J
    Charlie J Very Active Member
    1,876
    7
    38
    Oct 1, 2006
    Midwest
    you sure got a lotta ideas huh bogie?
  6. Bogie
    1,972
    Was figuring smaller would be better - it'll need to fit into a relatively small mobile space. Actually 12-13" would be wide enough, about the size of an Epson 1280, but I suspect that the ink would kill one of those in fairly short order.
  7. rcook99
    rcook99 Very Active Member
    2,139
    3
    38
    May 25, 2006
    NE
    Bogie, Is there any way you can print your products in house and then take them with you, or are these all one off prints as people purchase them?
  8. OldPaint
    OldPaint Major Contributor
    some 24" ones out there..............
  9. threeputt
    threeputt Very Active Member
    3,389
    1
    38
    Mar 10, 2006
    washington state
    Wise ***.
  10. Bogie
    1,972
    Actually, thinking of a small and somewhat mobile print-on-demand system.
  11. schurms
    schurms Member
    461
    I would think it doesn't get any cheaper than a mutoh jr. I bought one on ebay, and after the rebuild it was about $4000. You've got one already maybe you should have two.
