Arizona 180 problem.. need some help
Discussion in 'Miscellaneous Printers' started by WB, Apr 8, 2006.
  1. WB
    WB Active Member
    843
    1
    18
    Feb 9, 2006
    Canada
    we recently purchased a used arizona 180. I have a 90 it's in very good shape 2 years old.. only about 10,000' have been through the printer..
    this new(used) 180 has 65,500' through it and ahs been modistly taken care of IMO.. Today I took on the task of getting the 180 up and running in our shop for the 1st time.. everything went well.. Except!! I keep getting a "check Heater/Blower fuses" error
    when I 1st turned on the printed I noticed it was very quite.. but I wasn't sure why.. later on I realized the blowers are not coming on. I also noticed that the heater is coming upto temperature but it's staying at the set temp.. it keeps raising up and up.. untl I get the error...
    I've checked the connection on the blowers.. I've replaced the fuses with new ones.. still nothing..
    any help would be great
  2. skyhigh
    skyhigh Major Contributor
    4,866
    10
    38
    Jun 16, 2005
    PA
    I know nothing about these machines, but it sounds like a thermostat problem. Would the blowers kick on when a certain temp is reached, or are they supposed to be on constantly?
  3. signage
    signage Major Contributor
    9,497
    71
    48
    Oct 5, 2005
    Penn
    Have you pulled the fan and see if it works? The voltage rating should be marked on it. I don't know about these machines but I would start looking at the obvious.
  4. WB
    WB Active Member
    843
    1
    18
    Feb 9, 2006
    Canada
    just an update,,, narrowed it down ,, one of the blower fans was siezed up thats why it kept blowing fuses..
  5. Cadmn
    Cadmn Very Active Member
    2,859
    that'll do it ever time :)goodluck
