Asphaltum Alternative for Gold Leaf?
Discussion in 'Hand Made Signs' started by Billct2, Jan 20, 2011.
  1. Billct2
    Billct2 Major Contributor
    7,596
    685
    113
    Mar 12, 2005
    New England
    I have a sailboat silhouhette routed out of PVC. It will be gold leafed. I want to add some details to define the elements of the boat, deck, mast etc and thought I might do it like asphaltum was used to shade fire truck gold leafing. But I don't have asphaltum and was wondering if anyone did this with something else. Maybe using brown one shot mixed as a glaze?
  2. Pat Whatley
    Pat Whatley Major Contributor
    8,605
    89
    48
    Sep 29, 2003
    Wetumpka, AL
    I've airbrushed gold leaf and imitation leaf with One Shot before with no troubles. I don't see why thinned glazes would work any differently.
  3. Mike Paul
    Mike Paul Major Contributor
    5,441
    8
    38
    Dec 30, 2003
    NJ
    You could burnish it it different directions. I use to do that to make prismatic looking letters with golds leaf.
    Glaze with a tinted clear would work too.
  4. Billct2
    7,596
    685
    113
    Mar 12, 2005
    New England
    I've been researchng and found multiple methods, which can be as much a problem as no answers. The ones that I'm leaning towards are frog juice tinted with one shot or just thinned one shot.
  5. Mike Paul
    5,441
    8
    38
    Dec 30, 2003
    NJ
    Tinting Black mixed with clear is what I use.
  6. Billct2
    7,596
    685
    113
    Mar 12, 2005
    New England
    Mike Paul , what clear do you use? Chromatic?
  7. Mike Paul
    5,441
    8
    38
    Dec 30, 2003
    NJ
    Chromatic and 1-Shot. Frog Juice will also work.
  8. Billct2
    7,596
    685
    113
    Mar 12, 2005
    New England
  9. Fitch
    Fitch Member
    369
    1
    Why not raise (with say MagicSculp[Abracadabra]) or chip into (Dremel or chisels) BEFORE sizing and gilding?
    Just curious and you get EXACTLY the detail you are after.
    Cheers - G
  10. Billct2
    7,596
    685
    113
    Mar 12, 2005
    New England
    The piece was routed with some of the details, but I just don't think they're going to be
    defined enough when it's all gold leafed. So I want to shade the recessed areas, but in a transparent way.
  11. Fitch
    Fitch Member
    369
    1
    You could also use differing grades of gold from different suppliers.
    I have also found a different "brightness" level between patent (the wax paper one) and loose leaf.
    Also - most importantly - undercut - this will give you shading and definition. The deeper the undercut - the greater the definition.
    Also "round" the tops of some of the undercuts - divoting just before the top edge.
    To give you an idea - take a coin and see how the dimension works - have a look at the definition and how the most minute cut can create amazing detail.
    Hope this helps -
    Cheers - G
  12. Billct2
    7,596
    685
    113
    Mar 12, 2005
    New England
    thanks
  13. round man
    round man Active Member
    637
    1
    alsphaltum is basically a varnish made from bitumen,...it is basically refined tar roofing cement if you strain it and thin it properly the old fashioned roofing patch should suffice,..check the contents on the label and be sure it is traditional oil and asphaultum based,not the newer water based and recycled tire rubber latex substitutes,..
    The technique for doing shades with it are basically like tole painting,..you wet one side of the brush with the asphaultum and then pallette the brush with some clear till you get an even stroke that is dark on one side and almost clear on the other,...done properly it is an art form in itself,...
    edited to add,...you'll have to clear over it when you are through,...true asphaultum varnish will not dry hard enough to stand up to any weather,..ever see an antique chair with a finish on it like a thin layer of tar? thats asphaultum varnish,..it will stay sticky for hundreds of years,...
  14. Billct2
    7,596
    685
    113
    Mar 12, 2005
    New England
    Thanks for the info
