Attaching edge caps to Alumalite
Jillbeans
What is your preference?
For years I have used silicone but I am not 100% pleased with it.
:thankyou:
Love....Jill
Craig Sjoquist
Availability here is only the plastic C channel for 4 mil size that fits tight .. so like to read more comments here ...good post
Jillbeans
That's exactly what I am talking about, I should have been more specific.
The edge caps fit on very snugly but I like them to stay on.
I recently tried a latex-based adhesive which was supposed to dry clear.
It never dried!
SignManiac
PL adhesive usually works well. Just scruff up the inside surface with some sandpaper or a file so it's not slickerish.
daveb
General Know-it-all
Thing is your edging expands and contracts more than your Alumalite, will work most adhesives loose. I have cut 3M VHB foam tape down and applied it to the edge of the Alumalite then slipped the trim on with some success. There's also a clear adhesive called "Goop" (I think) for automotive trim, it's sold in the Auto department in Wally World, I've used it on other stuff but haven't had a chance to try in on this specific use, great stuff though.
Sign_Boy
daveb - you had me up until you mentioned the "W" word - that place is the devil JMO - thanks for the tip
When I first showed up at this shop they were using white "Tub and Tile" acrylic adhesive... I kept thinking it was a baaad idea, finally did a test in the shop and I switched to Silicone.
Since then I have used Lexel Clear and Silicone II on a consistent basis and have had pretty good luck. The biggest thing I have as a tip is to make sure that the edge of the Alumilite is clean of any cutting debris...
signgal
Yeah, the customer doesn't always get that they are just trim either. They think it's a stinkin' frame and they can haul around a 4x8 sign just holding onto the trim.
What about gorilla glue... I know it's not clear but if you don't goop it on?
bob
I use Gorilla Glue. Just a bit every 6 inches or so on the Alumalite, not the edging. Haven t had a failure yet. I always run a diagonal of blue tape across each corner so there's no question the this is edging and not part of the board. I hope the clients remember to remove it before they put up the sign.
signgal
Thanks, Bob! great idea and I'm gonna try the Gorilla Glue next time... hmmm you're not so mean and scary after all
