Autocad Corrupt/Invalid File
thibcormier
Hi all,
I am facing an issue that most of our autocad 2007 drawings are getting corrupted or invalid file which accessing it after couple days.
I need your help please.
backerg
Comprehensive source: http://www.filerepairforum.com/foru...-cannot-open-file-open-cad-drawing-dwg-format – must be helpful to you, forum contains some interesting thoughts about .dwg files
If the drawing file (DWG) still not opens, perform the following steps in the order listed:
Open the drawing file
Type PURGE at the command line. With all checkboxes checked on, click Purge All.
Purge Registered Applications (from the command line):
-Purge
"R" for Regapps (registered applications), then Enter
"N" when asked to verify each name to be purged, then Enter
Purge All (from the command line):
-Purge
"A" for All, then Enter
Audit and fix any errors
Type AUDIT at the command line
"Y" for Yes to fix any errors, then Enter
Save the drawing file
If previous solutions aren’t helpful to you, try to use DWG Viewer Tool
Demo version:- http://www.dwg.viewertool.com/
